2002 Chevy Avalanche no dash gauges, third gear starts
110,000 MILES • V8 • 4WD • AUTOMATIC
GERALD CHILSON
i have a 2002 avalanch and cant seem to find the problem. when i start the truck i dont get any gauges, and it starts in third gear. i dont have any first or fourths gear. the problem has gotten worse, i used to be able to restart and the problem whent away. not now! i took it to the tranny shop but they couldnt get it ot not work. if i manually put the car into second it will start in second and i can shift to third. but starting out is dificult in third. it seems like sometimes if i turn the wheel it will catch and the gauges will come back but i still have a third gear start problem. and sometimes it runs perfect. any answers?
Mar 4, 2008 at 10:08 AM
DENNYP
  • 1,824 POSTS
You need to check the voltage outputs from the ignition switch. Make sure they each have 12 volts.
Mar 17, 2008 at 3:41 PM
