engine displays error code missfire.
idles rough and problem is worse in colder temps
Nov 21, 2008 at 12:07 AM
✓Experienced Mechanic
Hi:
Were you able to determine which cylender was the problem? It could be a few things causing the problem, but most common is a weak coil pack in the affected cylender. I also could be a fouled spark plug. Was the engine tuned reciently?
