2002 Chevy Avalanche loosing coolant
2002 CHEVROLET AVALANCHE
BBCCW
Engine Cooling problem
2002 Chevy Avalanche V8 Four Wheel Drive Automatic 103k miles
I AM LOOSING COOLANT ABOUT 1 GALLON EVERY 2 WEEKS.NO SMOKING,NO OVERHEATING,RUNS STRONG ?
Nov 18, 2008 at 8:25 AM
  • 31,937 POSTS
Hi there ,
Thank you for the donation,
You should start with having the cooling system pressure tested as this will locate any external coolant leaks, also have the pressure cap tested, start here and report your findings.
mark (mhpautos)
Nov 18, 2008 at 9:01 AM
BBCCW
[quote:5f3397395f="bbccw"]Engine Cooling problem
I AM LOOSING COOLANT ABOUT 1 GALLON EVERY 2 WEEKS.NO SMOKING,NO OVERHEATING,RUNS STRONG ?[/quote:5f3397395f] IT HAS BEEN PRESSURE TESTED AS GOOD...
Nov 18, 2008 at 9:36 AM
  • 31,937 POSTS
OK, the coolant can only go two places, that is an external leak, or internally, so if the pressure test has been done correctly and there is no external leaks, it must be an internal problem, you can have a head check done, this is a chemical test done in the cooling system, that detects exhaust gasses in the coolant, this is a sure sign of a combustion leak, get this done next.
mark (mhpautos)
Nov 18, 2008 at 9:42 AM
