2002 Chevy Avalanche Key lock tumbler/ignition switch
DISCONTENT
Computer problem
2002 Chevy Avalanche V8 Two Wheel Drive Automatic 185XXX miles
Someone recently attempted to steal our avalance. They were unsucessful in stealing it, but succesful in breaking most of the ignition assembly. My question is, after changing out the key and switch do i need to have the computer reset? I was told the new tumbler has a code and the computer wont recognize it, and wont start. If so is this a DIY type of thing, or will i be forced to bring it to a shop?
Thanks
Oct 14, 2010 at 4:14 AM
WRENCHTECH
  • 20,760 POSTS
30 Minute Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON; the vehicle will not start.
3. Observe the SECURITY telltale; after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes; the vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important: The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
7. With a scan tool, clear any DTCs, if needed. History DTCs will self clear after 100 ignition cycles.
Oct 14, 2010 at 4:22 AM
DISCONTENT
Have attempted what you suggested a couple times now, and I still havent been able to get the truck to start. I have yet to re-install the steering wheel/airbag, and was wondering if that could also cause the truck to not start.
Oct 15, 2010 at 10:42 AM
WRENCHTECH
  • 20,760 POSTS
If your security light is on or flashing and the relearn isn't working, then it still has a hard failure somewhere. You will need a Tech2 scan tool to diagnose it.
Oct 15, 2010 at 10:58 AM
DISCONTENT
double post sorry.
Oct 15, 2010 at 11:52 AM
WRENCHTECH
  • 20,760 POSTS
I already responded to that.
Oct 15, 2010 at 11:54 AM
