2002 Chevy Avalanche IGNITION KEYS
67,855 MILES • V8 • 4WD • AUTOMATIC
MAZZAH
Yesterday my Chevy started this problem:
A- The key would not move out of the drum.
B- The gear would not go to park
C- When I finally managed to remove the key it did not cut the " Juice" (Battery). As a result I was left with a dead battery needing a jump.
What should I do?
My mechanica said that the best ting to do are to take the car to a Dealer and replace the whole thing: New Drum, New Keys, bla, bla, bla.
Thanks
Dec 31, 2007 at 3:01 AM
DENNYP
  • 1,824 POSTS
It could be a broken ignition switch and not the ignition cylinder. You will need to remove them both to check them. See which one doesn't move correctly.
Dec 31, 2007 at 4:58 AM
