2002 Chevy Avalanche CHECK ENGINE LIGHT
128,000 MILES • V8 • 4WD • AUTOMATIC
JOEGUTIERREZ
CHECK ENGINE LIGHT CAME ON, TOOK IT TO REPAIR SHOP, NEEDED 2 SENSORS AND CATALYTIC CONVERTER REPAIRED, THEY CHANGED OUT SENSORS, BUT I COULD NOT AFFORD THE CATALYTIC CONVERTER, WILL TAKE IT BACK, WELL SINCE THEN MY SERVICE ENGINE LIGHT DOES NOT COME ON AT ALL WHEN I TURN ON MY VEHICLE, DO YOU THINK THE LIGHT WAS DISC, AND IF SO HOW COULD I CHECK???
Feb 27, 2008 at 6:25 AM
BLACKOP555
  • 10,386 POSTS
Chances are when the replaced the O2 sensors they were misreading and it caused the code about the convertor. if it hasnt showed up you have nothign to worry about.
Feb 27, 2008 at 10:27 AM
