wont start
FESTERJA
98 astro awd 4.3 165000 i have spark and fuel pressure is at 62psi i just replaced fuel pump started but barely all fuses good could it be the control module if i wiggle the plug it fires for a second then just turns over again
Nov 6, 2007 at 4:27 AM
  • 75,988 POSTS
Last major tune-up?
Double check the ICM and also check the pick-up coil resistances in the distrubutor with an ohmmeter should between 500 and 1500 ohms.
Nov 6, 2007 at 7:04 AM
