1991 Chevy Astro Won't Start
UNOME95361
my 91 chevy astro van won't start i ran out of gas at the gas station i felt like the filter was cloged before i even ran out of gas and then i started it after i put 3 gallons in and it ran very dieing like and i kept pumping the gas peddle we went a block and a half and it died and wouldn't start again i replaced the filter and still wont start do you have any sugestions i would appreaite any sugestions you have to help fix it i am disabled and cant walk far and i don't have money for a taxi all the time and definataly cant go out of town.thanks a lot ahead of time
Aug 26, 2007 at 9:13 AM
  • 75,988 POSTS
[quote:0dd6d9823e="unome95361"]my 91 chevy astro van won't start i ran out of gas at the gas station i felt like the filter was cloged before i even ran out of gas and then i started it after i put 3 gallons in and it ran very dieing like and i kept pumping the gas peddle we went a block and a half and it died and wouldn't start again i replaced the filter and still wont start do you have any sugestions i would appreaite any sugestions you have to help fix it i am disabled and cant walk far and i don't have money for a taxi all the time and definataly cant go out of town.thanks a lot ahead of time[/quote:0dd6d9823e]
An engine that refuses to start needs 4 ingredients that is Speed/Compression/Fuel/Ignition to fire up.
Start by check the actual fuel pressure-could be the in-tank pick-up screen or fuel pump.
Aug 27, 2007 at 9:14 AM
SERVICE WRITER
  • 9,123 POSTS
Welcome to my world TM1, I deal with it daily in front of people. Working on the forum is ten times more difficult. There are a wide variety of people that range from skilled to ones that can't check oil. Sometimes you can supply that magic bullet that solves the problem right away, but most of the time you need to play detective, technician and teacher. Ask the questions to know where to go and advise carefully as we all can go down the wrong path from time to time. But also remember to be as respectful as you can. Insulting a member surely will not get the answer you need. Your technical presence is welcome and qualified.
https://images.2carpros.com/forum/automotive_pictures/30961_crosbypeace_1.jpg
Your Hippy-type, pinko, MOD, And I don't even own a garage, you can call and ask my wife.
Aug 28, 2007 at 8:58 PM
Suggested Repair
Check actual fuel pressure. After running out of gas and replacing the filter, suspect a clogged in-tank pickup screen or a failing fuel pump.
Conversation Summary
A 1991 Chevrolet Astro would not restart after running out of gas. It briefly ran poorly after three gallons were added, then died a short distance later. Replacing the fuel filter did not restore starting. The expert said a no-start needs cranking speed, compression, fuel, and ignition, and advised checking fuel pressure, noting the in-tank pickup screen or fuel pump as possible causes.
