1993 Chevrolet Astro Runs After Key Off
PIPE4YA
I have a 93 chevy astro 4.3 liter engine with 147000 miles. Recently it was serviced for a new fuel pump and gas filter. A week after being that when I turn the van off and take the key out it continues to run. For me to get it to stop running I have to disconnect a plug (2 wires) going to the distributor. One thing I know that it's not is run-on. Also the oil gague goes low to red when at a stop most of the time, but when pressing the gas peddal goes normal. Can you please help? The van runs perfect other than this.
Aug 27, 2007 at 8:38 AM
  • 75,988 POSTS
[quote:c6fccb286b="Pipe4ya"]I have a 93 chevy astro 4.3 liter engine with 147000 miles. Recently it was serviced for a new fuel pump and gas filter. A week after being that when I turn the van off and take the key out it continues to run. For me to get it to stop running I have to disconnect a plug (2 wires) going to the distributor. One thing I know that it's not is run-on. Also the oil gague goes low to red when at a stop most of the time, but when pressing the gas peddal goes normal. Can you please help? The van runs perfect other than this.[/quote:c6fccb286b]
Could be caused by vacuum leak,binding throttle body plate not closing completely, problem with IACV,engine overheating, hot spots in cylinders acting like sparkplugs, and ignition out of time.
Aug 27, 2007 at 9:06 AM
Suggested Repair
Check for a vacuum leak, a throttle body plate that binds and does not close fully, a faulty idle air control valve, engine overheating, cylinder hot spots, and incorrect ignition timing.
Conversation Summary
The owner of a 1993 Chevrolet Astro 4.3 says the engine keeps running after the key is removed and stops only when a two-wire distributor connector is unplugged. A fuel pump and filter were recently replaced, and the oil gauge often drops into the red at idle but recovers when the throttle is opened. An expert listed possible causes including a vacuum leak, a binding throttle plate, an IAC valve problem, overheating, cylinder hot spots, or ignition timing that is off.
