Thermostat replacement for astro van
DIAMOND JIM
Where is the thermostat on 1995 Chevy Astro Van?
Jan 10, 2006 at 11:27 AM
RAMAIR
The thermostat is located inside a housing, which is attached to the front of the cylinder head (2.5L) or to the front of the intake manifold (4.3L).
Jan 11, 2006 at 12:54 AM
BODHI
  • 12 POSTS
2CarPros editorial correction - October 12, 2026
The earlier brief thermostat-removal instructions were incomplete. Confirm the installed engine and obtain its service procedure before opening the system or removing a housing. Let the engine cool fully and never remove a coolant pressure cap while the system is hot or pressurized. Follow the specified draining, replacement, fastening, refilling and bleeding procedure. The discussion does not establish a complete procedure for this Astro.
Jan 12, 2006 at 10:13 AM
