1997 Chevy Astro No Reverse
KAPANA
1997 Chevy Astro Van, Rear-wheel drive, 133,000 miles. Shifted into reverse and it simply didn't work. No warning. No nothing. The car revs up like it wants to go, but nothing happens. What might be the problem? Is this something I have to take to the dealer to fix?
Jan 20, 2006 at 2:06 AM
2CARPRO JACK
  • 11,533 POSTS
If the forward gears work the trans needs a rebuild
Feb 3, 2006 at 7:53 AM
KAPANA
Thanks for the tip. Turns out that it did need a transmission rebuild and it now runs find.
Feb 3, 2006 at 8:32 AM
Suggested Repair
If the forward gears still work, the transmission needs a rebuild.
Conversation Summary
A 1997 Chevy Astro van with 133,000 miles would not move in reverse; the engine revved but there was no movement and no prior warning. The expert said that if the forward gears work, the transmission needs a rebuild. The owner later confirmed a transmission rebuild was required and the van then ran fine.
