Rear Hatch window will not unlock
DESERTRIDER1959
1995 Astro 4.6L
One side will not unlock and allow window to open (so double doors can not be opened either) How can I manualy unlock the rear hatch window so I can take the door apart to start to work on why one side will not unlock? With the door locked I can not take the inside trim/pannel off.
Thank you
Randy McDonald
Aug 11, 2007 at 4:27 PM
  • 75,988 POSTS
[quote:da408c13d1="mata36"]HOW CAN I CHECK IF GAS IS GOING TO THE ENGEING AND HOW CAN I CHECK IF THE ENERTIA SWICTH IS WORKING ON A 98 FORD EXPLORE 6 CYLINDER 4.0[/quote:da408c13d1]
Remove a spark plug and look at it if its wet, the 2nd one is --if you can hear the pump then its still good it has to go thru the inertia switch. If you don't hear the pump than it needs checking- at times it can go whacko on and off and give you the curve ball.
Its located behind the R/Front kick panel.
Aug 11, 2007 at 5:38 PM
MATA36
  • 17 POSTS
if you hear the buzzing noise from the fuel pump that mean it turns on and it you see its througs pruser out when you disconnect the gasline from thr fuel rilter that means it througs presure out, is there a posebility that still not working.
ford explore 98 6 cylinder 4.0
Aug 12, 2007 at 3:17 AM
98RANGERXLT
  • 301 POSTS
If you took the fuel line off of filter and powered up fuel pump than the inertia switch might have tripped because it saw that there was a fuel leak.
Aug 12, 2007 at 2:58 PM
