I have a 2000 Chevy Astro that has 335,000 miles on it. It has been a great vehicle. I am however having a problem with it starting. The only time I have this problem is when we have some rain. Whether it be a storm or a mist. Sometimes a heavy dew will cause it not to start. It will crank but just not turn over. I originally had a problem with my fuel pump. It made no sound at all. I replaced it along with the fuel filter. It ran fine for a week or so then I started having this problem. I have since changed the distributor, rotor button, and distributor cap. Could this be an injector problem or something simple I am overlooking? I was also wandering about the ignition module. If it could be the module where is it located?
Nov 26, 2007 at 7:37 PM
