Power Steering and brakes went out on 95 Astrovan 4.3L.
1995 CHEVROLET ASTRO
HERMAN
I have a 95 Astrovan with a 4.3L with 200,000 Kms. Both power steering and brakes went out at the same time. The serpentine belt and fluids are all fine. Everything else seems to be working but it is very difficult to stop and turn.
Can you help me?
Apr 7, 2007 at 4:23 AM
BOOTDOG
  • 665 POSTS
you probably have hydro boost system, which the power steering fluid runs through the booster to give you power brakes. i believe the pump went out and isn't circulating the fluid. change the pump and you should be fine.
Apr 7, 2007 at 8:46 AM
