nothing happens when key is turned
BIRDDOGDAD
Hi. I have a 1994 4 cylinder chevy s10 pickup with 70,000 miles. I thought I had a bad battery but not so. When the key is turned nothing happens. No turning over sounds no clicking, nothing. The lights, radio and blower all work. It is in park, I did shift in and out of gear to make sure. I installed a new battery and it's all the same result. The fuses are all ok. We have had below freezing temps for about two weeks and it sits outside.
Thanks for any help!! BirdDogDad
Feb 8, 2007 at 7:36 AM
MIKE H R
  • 3,094 POSTS
with it beeing that cold i believe it might be the starter solinoid. if it clicked then it would be the starter. try taping the starter with a hammer lightly. have heard sometime it works,
Feb 8, 2007 at 8:06 AM
MARIONICANOR
yeah man it is the starter my friend has a 64 chevy impala and it did the same thing but he also had to change the spark plugs and the spark plug wires
Mar 20, 2007 at 12:38 PM
BIRDDOGDAD
It was the starter. Thanks for the help!!!!!!!
Mar 20, 2007 at 3:18 PM
MIKE H R
  • 3,094 POSTS
you are welcome
Mar 21, 2007 at 10:31 AM
