Left blinker fast -- right blinker fine
DARKMAGE2002
My left turn signal is blinking at a very fast temp. I have no experience in car repair whatsoever and don't want to get "taken to the cleaners". I've read a few messages on other boards and have developed a few theories.
Do I just need to change the flasher? And if so, what is this? Where do I find it? How easy is it to change and how much will it cost me to do it myself?
I haven't checked any fuses yet. Should I, considering that the right blinker is still working fine?
Is there any chance this is going to be a much more serious job -- like maybe something inside the steering column that needs to be replaced?
Jun 11, 2007 at 2:58 PM
HEATHERLEA213
Hi There!
This might be like the 'blind leading the blind' because I don't have any repair experience either; BUT, I do know that on my Mitsubishi, when that happens, it means a bulb is out.
I would park the car with it running, put the left blinker on, and get out and look at the front and back turn signal. I'd bet one of them is NOT flashing. Once you replace the bulb (cheap) it should be fine.
HOPE THAT WORKS!! Good luck!
Jun 12, 2007 at 11:03 AM
