hooking up trailer lights for 93 chevy astro van
PFLICK
I have not been able to figure out how to hook up my trailer lights for my 93 chevy astro van. I took the van to a mechanic and he says that he cannot figure it out either, he tried to hook them up and when I got home they did not work. So, I bought a plug in tester for the hook up and it did not work. I have tried the tester on another vehicle and the tester worked on that vehicle. So, I know that the tester is good. I would like to know where I could get some sort of diagram that would show me how to hook up the trailer lights, and I dont know where to find one at. Could somebody please help me with this problem??
Jan 10, 2006 at 2:40 AM
2CARPRO JACK
  • 11,533 POSTS
at the rear of the vehicle locate the taillight wiring. Blk is groung, brown is running lights and yellow is left turn/brake (same wire) and green is right is turn/brake (same wire)
Jan 10, 2006 at 4:17 AM
Suggested Repair
At the rear of the vehicle, locate the taillight wiring and connect the trailer lights as follows: black is ground, brown is running lights, yellow is left turn/brake (same wire), and green is right turn/brake (same wire).
Conversation Summary
The owner of a 1993 Chevy Astro van could not get trailer lights working after a mechanic tried the hookup, and a known-good plug-in tester showed no function on the van. The expert identified the rear taillight wire colors: black ground, brown running lights, yellow left turn/brake, and green right turn/brake.
