1997 Chevrolet Cavalier Heater No Air
FANTASYG3
I have a chevy cavalier 1997, 120000 miles.
the problem it's that I took it to a repair shop to see why the motor was making too much noise. They ended up replacing the motor. everything works fine, but this morning the heater won't turn on, don't blow any air. I check all the fuses and they are ok. took it back to the shop and they said they don't know what's happened. can you help me?
I'll appreciated it very much.
Feb 8, 2007 at 5:21 PM
  • 75,988 POSTS
[quote:f4c06fc97d="fantasyg3"]I have a chevy cavalier 1997, 120000 miles.
I'll appreciated it very much.[/quote:f4c06fc97d]
Probably a disconnected wire connector to the blower motor or a resistor
Feb 8, 2007 at 7:58 PM
Suggested Repair
Check for a disconnected wire connector at the blower motor or a failed blower motor resistor.
Conversation Summary
A 1997 Chevrolet Cavalier with 120,000 miles stopped blowing heater air after a shop replaced the engine. Fuses were checked and found good, and the shop could not explain the problem. The expert suggested a disconnected blower motor connector or a bad blower resistor.
