Fuel pump problem
VIOLETB
I have a 2000 Chevy Astro Van that has been sitting for two years. Trying to get it up and running. The fuel pump is not pumping gas. All fuses are OK and gas OK. Can not hear fuel pump when turning on.
Any help would be appreciated. Des this van hasve similiar electronic emissions module like an 89 Chevy 1500 and if so where is it located?
Thanks
Sep 12, 2007 at 10:44 AM
  • 75,988 POSTS
[quote:34b40bc0c6="violetb"]I have a 2000 Chevy Astro Van that has been sitting for two years. Trying to get it up and running. The fuel pump is not pumping gas. All fuses are OK and gas OK. Can not hear fuel pump when turning on.
Thanks[/quote:34b40bc0c6]
Sir
I need to know what liter engine before we can proceed-thanks
Sep 12, 2007 at 11:16 AM
VIOLETB
It's a V6
[quote:573bef2c4a="rasmataz"][quote:573bef2c4a="violetb"]I have a 2000 Chevy Astro Van that has been sitting for two years. Trying to get it up and running. The fuel pump is not pumping gas. All fuses are OK and gas OK. Can not hear fuel pump when turning on.
Thanks[/quote:573bef2c4a]
Sir
I need to know what liter engine before we can proceed-thanks[/quote:573bef2c4a]
Sep 12, 2007 at 11:19 AM
2CARPRO JACK
  • 11,533 POSTS
RAZ... 2000 Astro's only came with 4.3's
Sep 13, 2007 at 12:47 AM
  • 75,988 POSTS
[quote:e6082e9d3c="2CarPro Jack"]RAZ... 2000 Astro's only came with 4.3's[/quote:e6082e9d3c]
Thanks
Talking about 4.3 I got one under a Bravada 93 with that crazy CPI Vortec crappy stuff. That don't impress me-all digital
Yeap! you're right, check it again-I probably misque the year.
Thanks
Lets do this find the fuel pump connector-use a voltmeter not a test lite while key is in On position do this real quick-all you got is to 2secs. what is your voltage reading? No power there-inspect and test fuel pump relay. then report back.
Be advised that the computer energizes the relay-I'll be waiting.
Sep 13, 2007 at 2:02 AM
