dash lights
CHEVROLET ASTRO
BENNYLEROY
  • 10 POSTS
I have a 1992 gmc safria 170,000 miles my dash lights were not working I changed the blown fuse, as soon as I turn the lights on it the blows the fuse. I replaced the dimmer and head light switch. What else can I check? thank you!
Feb 24, 2007 at 9:37 AM
MIKE H R
  • 3,094 POSTS
Check the wireing to see if anthing is grounding out causing a overload blowing th fuse, check the dash light bulbs.
Feb 24, 2007 at 9:45 AM
2CARPRO JACK
  • 11,533 POSTS
Any aftermarket equipment? ie... car alarm, stereo?
anything that might have been tapped into the wiring
Feb 25, 2007 at 12:00 AM
BENNYLEROY
  • 10 POSTS
Yes, I installed a car stereo 4 years ago I re-checked the connections all were fine.
Feb 25, 2007 at 5:14 AM
BENNYLEROY
  • 10 POSTS
[quote:cb85ca2a84="techman1"]OK, so you say it blows the fuse when you turn the lights on. Go around and remove all the parking light bulbs and see if it holds the fuse. Then, replace the parking light bulbs one at a time. I think it will be a light socket or wiring to one.
Good Luck,
Ken[/quote:cb85ca2a84] Ken, The fuse for my dash lights blow,Why woud the parking lights blow the dash light fuse when there is a seperate fuse for parking lights? that fuse is ok... "im conFUSED"
Mar 1, 2007 at 4:26 AM
