cooling fan
DANSOUTH
1998 chevy cavalier 2.2L SFI with 58,400 miles cooling fan only works with ac on ive replaced coolant temp sensor and relay what else could it be
Aug 27, 2007 at 9:14 AM
  • 75,988 POSTS
[quote:607a6f55e6="dansouth"]1998 chevy cavalier 2.2L SFI with 58,400 miles cooling fan only works with ac on ive replaced coolant temp sensor and relay what else could it be[/quote:607a6f55e6]
Could be a temperature switch other than the CTS-maybe the fan motor try running it direct to the battery to eliminate it.
Aug 27, 2007 at 9:19 AM
DANSOUTH
[quote:a1c713228b="rasmataz"][quote:a1c713228b="dansouth"]1998 chevy cavalier 2.2L SFI with 58,400 miles cooling fan only works with ac on ive replaced coolant temp sensor and relay what else could it be[/quote:a1c713228b]
Could be a temperature switch other than the CTS-maybe the fan motor try running it direct to the battery to eliminate it.[/quote:a1c713228b] Fan works ok with ac running. just wont work if not using ac.cant find no temperature switch dont think there is 1 but not sure
Aug 29, 2007 at 1:33 AM
