[quote:a1c713228b="rasmataz"][quote:a1c713228b="dansouth"]1998 chevy cavalier 2.2L SFI with 58,400 miles cooling fan only works with ac on ive replaced coolant temp sensor and relay what else could it be[/quote:a1c713228b]
Could be a temperature switch other than the CTS-maybe the fan motor try running it direct to the battery to eliminate it.[/quote:a1c713228b] Fan works ok with ac running. just wont work if not using ac.cant find no temperature switch dont think there is 1 but not sure
Aug 29, 2007 at 1:33 AM
