How to remove alternator & engine cover. Cannot find top two bolts on engine cover. :evil:
May 26, 2006 at 10:04 AM
LOSONE
✓Experienced Mechanic
You shouldn't have to remove the cover to replace the alternator but the 2 bolts are between the dash and the cover. If you have some things like a cup holder remove it and look carefully and you will see one on each side. Good luck
