the brakes and power steering went out at the same time, i have an astro 1996 chevy van. Any idea what could be the problem
Sep 7, 2007 at 9:04 AM
MERLIN2021
✓Experienced Mechanic
Check the power steering reservoir, Your van has the hydro-boost power booster, it runs off the power steering, not vacuum! Check fluid and belts.
Sep 7, 2007 at 9:59 AM
SUGARPEA421
MEMBER
[quote:cd0e412ab7="merlin2021"]Check the power steering reservoir, Your van has the hydro-boost power booster, it runs off the power steering, not vacuum! Check fluid and belts.[/quote:cd0e412ab7]
i have already checked all of that could it be a fuse
Sep 7, 2007 at 10:03 AM
MERLIN2021
Not likly...think power steering pump...
Sep 7, 2007 at 1:47 PM
SUGARPEA421
MEMBER
[quote:74ffdb101e="merlin2021"]Not likly...think power steering pump...[/quote:74ffdb101e]
What is a good way to check if it is the power steering pump?
Sep 8, 2007 at 2:04 AM
MERLIN2021
Disconnect a high pressure hose and plce end in a bucket, have a helper start the car, fluid should come out of the hose with a lot af force! Be prepared to turn on and off quickly!
