battery drain
GSTORER
I have a 97 chevy astro van (v6) with about 200000 miles. started to notice electronic issues, clock resetting, about two months ago. the battery is about a year old. it drains itself while the car is not running, brought it back to a full charge, started and ran fine, a day later, it is completely dead again.
trying to jump to recharge the battery. wont turn engine, just a clicking sound? any suggestions are GREATLY appreciated!
Nov 25, 2007 at 1:14 AM
  • 75,988 POSTS
Disconnect the positive battery post and put test light in between the disconnected cable and battery positive post is the test light lit-if so start removing fuses one at a time the one that turns off the light is the trouble circuit.
Nov 25, 2007 at 1:22 AM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Sun Nov 25, 2007 9:52 am
Subject: battery drain
I notice there are large fuses inside the engine area and small ones under the dash. do I test all of them. really appreciate your help!
Sir,
You must test all of them
Nov 25, 2007 at 8:20 AM
MRFUNSUB
your glove box dor may not be completely closing -- i had the same problem and i just disconnected the glove box light bulb and never had the problem again.
hope that helps!
mark
Nov 25, 2007 at 10:06 AM
