Astro mini van! HELPP!
KRISTY5209
I have an 1993 astro mini van which has 186,000 miles on it. Its an automatic transmission and 4 wheel drive. There is one strange sound that nobody knows what it is. It sounds like the wheel bearing but I had them all changed & it only does it when your going past 35 miles per hour & rarely will do it in overdrive. It sounds like a humming noise sounds like its coming from the passenger side dashboard. There is no fluid leaks, which i just replaced the water pump last night. But the problem is the air filter has not been changed for a very long time. My boyfriend & Dad looked at it & realized you have to take the dashboard off to get to it. The guys at monro & wal*mart said the same thing. When we took the dashboard off there was no sign of an air filter. I need to change it bad but do not know how. Can you please help? :(
Jul 18, 2007 at 6:14 AM
KRANZ PHOTO
  • 5 POSTS
Take off the engen cover, (not the dash), thats the big round hump looking thing between you and the passanger. Then unbolt the cover from the air filter housing, its a round looking thing that sits on top of the motor.
Aug 25, 2007 at 2:00 AM
