2004 Chevy Astro Vents wont open
124,000 MILES • 6 CYL • 2WD • AUTOMATIC
BDDOUG
My AC comes on and blows cold air, but it wont switch to the console vents. It only blows out the defrost and lower vents. It does the same thing on just vent and heater settings as well.
Mar 19, 2009 at 9:57 AM
2CARPRO JACK
  • 11,533 POSTS
Most likely a broken vacuum line from the intake manifold on the drivers side to the a/c box on the pass side front of the van.It is a small plastic line that cracks/breaks all of the time.If you remove the air intake boot and filter assembly you should be able to see it
Mar 20, 2009 at 12:50 AM
