does the transfer case have to be removed to change oil pan gasket?
Mar 26, 2009 at 5:41 AM
BLUELIGHTNIN6
✓Experienced Mechanic
You will have to lower the front differential carrier assembly enough to remove the pan.
Thanks for using 2CarPros.com!
Mar 26, 2009 at 8:10 AM
