2003 Chevy Astro No pressure
2003 CHEVROLET ASTRO
182,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICKEY1100
It all started with changing the front calipers. Bleeding did not work so we replaced the rear ones cause we could not open the bleeders, everytihng was rusted. With 4 new calipers, bleeding did not work. So we changed the master cylinder and bleeding the whole system still don't work. We don't know what to do next.
Nov 17, 2008 at 11:48 PM
  • 110,240 POSTS
Hi:
Are you getting any pedal at all? Also, are the rubber brake lines in good shape (not expanding under a load)? Also, when you replaced the master cylender, was the plunger shaft adjustable? Finally, are you getting any brakes at all, did you bench bleed the master cylender, and when bleeding, did you start at the furthest wheel from the master cyl and work toward it?
Nov 19, 2008 at 2:07 AM
