2003 Chevy Astro heating
144,000 MILES • 6 CYL • AWD • AUTOMATIC
HOCHAS
The front heater blower moter will not work on high, also the vents will will not switch over to any position they are stuck in the defrost position. I have checked all fuses and the heater blower moter is new.
Jan 31, 2009 at 12:44 AM
GARYHUFF
with the Heater relay not energized they 20 amp Heater/ac fuse supplies Power for Low and Medium speed windings, High settings Energizes the heater blower relay (Via org wire on blower motor resistor and relay pack) and supplies power from the 30 amp Maxi
fuse. Be sure to check Both fuses. I am not sure what type damper controls are on that year but if they is a vacuum ported switch and bellow type actuators check to see if master line (from intake manifold ) is connected and supplying vacuum to the switch. The lines are very small and resemble 12 gauge wire but they are plastic tubes.
Jan 31, 2009 at 9:23 AM
