2003 Chevy Astro ELECTRIC DOOR LOCKS
JOSEPH RAMIREZ
Electrical problem
2003 Chevy Astro Two Wheel Drive Automatic
QUESTION ???
AT THE REAR OF THE VAN I HAVE THREE DOORS, TWO HALF DOORS AND A UPPER GLASS DOOR THE DOOR LOCK DOES NOT UNLOCK WITH THE REMOTE BUTTON OR THE KEY... ALL THE OTHER DOORS UNLOCK AND LOCK WITH THE REMOTE BUTTON ONLY, THE INSIDE BUTONS DO NOT WORK.. WHAT FUSE DOES IT WORK OFF OF AND WHAT ELSE SHOULD I LOOK FOR???
Jun 19, 2010 at 8:44 AM
  • 110,248 POSTS
Are you able to open it manually? If not, remove the door panel and check the linkage to the lock. Either it is disconnected or broken.
Jul 10, 2010 at 3:14 PM
