2003 Chevy Astro air flow stuck on defrost
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHUCKLE101
No matter where the selector is set, it seems like the majority of the air is coming out the defroster. This happened one time before and a dealer fixed it.
Jul 6, 2008 at 3:07 AM
MERLIN2021
  • 17,250 POSTS
Check for vacuum at the control head, if none , open the hood, locate the black supply line it runs off the manifold, to a check valve, to a reservoir cannister, and into the van. This line, check valve or cannister is leaking vacuum, or the actuator that controls the air distribution is leaking vacuum.
Jul 6, 2008 at 3:17 AM
