2003 Chevy Astro abs light
2003 CHEVROLET ASTRO
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
EDWKRAUS
If I do nothing to fix the light problem with my abs. I was told that my brakes will work fine but I won't have abs braking is this true. If so how do I turn off the lights.
Sep 8, 2010 at 8:50 AM
WRENCHTECH
  • 20,761 POSTS
Most of the time it is just an electrical issue and your regular hydraulic brakes will work normally however it is possible for the ABS system to cause hydraulic issues also. You would be the only one to know if there are any hydraulic issues or not.
As far as putting the light out, no, short of removing to dash to get the bulb out, fixing it is the only way that is going to happen.
Sep 8, 2010 at 9:23 AM
