2003 Chevy Astro
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHUCKYCHEESE
only occasionally wont start. cranks over with fuel and no spark. cranks with no attempt at starting. when it finally starts the security light is on. bad ignition switch? or crank sensor.
Aug 19, 2010 at 11:32 PM
WRENCHTECH
  • 20,760 POSTS
Your not going to know what caused it until you have the Passlock codes read and that will require using a Tech2 scan tool.
Aug 19, 2010 at 11:57 PM
