2002 Chevy Astro van won't stay on
SDMARES
  • 2002 CHEVROLET ASTRO
  • 6 CYL
  • 178,000 MILES
My van started to lose power taking off at a light or stop sing it would regain power slowly, on monday it finally stall while driving I replace distributor cap router spark plugs and wires fuel filter but won't work it cranks and turns but it wont stay on. Any suggestions?
Thursday, May 7th, 2009 AT 4:07 PM
If you're saying it cranks and won't start do below
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, May 7th, 2009 AT 4:31 PM
Related Engine Stall While Driving Content
