2002 Chevy Astro The Fan not work on up just on floor
2002 CHEVROLET ASTRO
309,000 MILES • 6 CYL • 2WD • AUTOMATIC
KORKORO
Hi there my heating system is not working on top parts only on floor . The blow engine work AC work too but only downster . Thank you for help.
May 23, 2010 at 4:01 AM
  • 110,240 POSTS
You either have a vacuum leak or a vacuum hose to the HVAC that has collapsed. Check for leaks under the dash. With the engine running, you may hear a hissing sound. Also, check under the hood for the same thing. Follow the vacuum supply hose from the control through the firewall and to the intake. I have not only found them dry rotted, but collapsed.
Let me know what you find.
Jun 1, 2010 at 3:19 PM
