what could cause friction or a rubbing sound while steering wheel is all the way left or right and in reverse?
May 24, 2010 at 7:47 AM
✓Experienced Mechanic
Check the inner fender to see if the tire is rubbing anything. Also, if you have mud flaps, check to see if they are touching the tires when you turn sharp.
