2002 Chevy Astro abs light wont go off
2002 CHEVROLET ASTRO
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
RONNIE1959
i recently replaced front rotors and pads and 1 year later the abs light was coming on for days at a time and every now and than it would go off.no it stays on steady and so i put new drums and shoes and hardware on the rear and it had no effect.i checked the fuse and it is good .i have noticed the master cylinder gets low more sonner than it used to .but i dont see any leaking fluid on the driveway from it and there was no wetness in any of the brake shoes or pads..can you help?...thankyou ron
Jul 12, 2008 at 6:49 PM
MASTERTECHTIM
  • 4,750 POSTS
this system, kelsey hayes uses a brake pressure modulator valve to run its abs system. you need to have the abs system checked for codes. its quite possible there is a internal short in system or you could just have a wheel speed sensor problem. but you must have it scanned for codes, that will give us a direction to go in.
Jul 12, 2008 at 8:09 PM
