I recently had my transmission replaced along with the differential, approximately 5000 miles ago. Yesterday my speedo started going crazy and the van started downshifting by itself. As I attempted to pull over I noticed that in 3rd gear and OD the van seemed to act like it was in neutral. If I would downshift manually all the gears would go in just fine except for 3rd........it would work until I got to 30mph and then act like it was in neutral again. I checked my trans fluid and its clear with not metal shavings....it even smells like new fluid. This might sound stupid, but could the ABS system have something to do with this??I have replaced everything that could go wrong with this van...Fuel pump, injectors.......etc and Im running out of money. Thanks
Oct 16, 2009 at 4:10 AM
