2001 Chevy Astro Radio and Lights
85,500 MILES • 4 CYL • 2WD • AUTOMATIC
ANDERSONTAXI
I have a 2001 Chevy Astro. The radio used to stay on for several minutes after turning off the ignition or until the door was opened. Then suddenly, it just stopped and it now turns off when the ignition is turned off. Also, about the same time, my interior lights started acting up. The lights don't come on when I open the door. I've tried resetting it by pressing the buttons as described in my owner's manual, but it doesn't work. Anyone know what's going on?
Also, the vents don't work except for the defrost ones by the windshield, but I think that's the vacuum line.
Jun 5, 2008 at 7:40 AM
MASTERTECHTIM
  • 4,750 POSTS
vacuum line is rotted out near engine to heater control, common problem. check for power at the interion light socket, there should be power there at all times. does the door ajar light come on when the door is open? fuses good?
Jun 5, 2008 at 8:42 AM
