2001 Chevy Astro Window Grinding
MACBERUMEN
on the pass. side window it goes up and down the middle third. when it stops a grinding noise could be heard. i want to know if it could be the motor or regulator, or even both. it does move so I'mnot sure what it is. Also how do I troubleshoot the problem? This came on with no warning. HELP THANKS!
Oct 7, 2007 at 3:57 PM
BOOTDOG
  • 665 POSTS
replace the window motor
Oct 8, 2007 at 12:31 PM
MACBERUMEN
[quote:823dc1169d="bootdog"]replace the window motor[/quote:823dc1169d]
thanks for the info. Is it a hard job to replace the motor & what all do I need to do the job once the panal is off. Should I get rivots seperate or do they come with the motor? THANKS
Oct 9, 2007 at 10:10 AM
BOOTDOG
  • 665 POSTS
every vehicle is different. i haven't done one on your model. mostly on fords. they can be very tricky if you've never done one. i do believe you can pop the panel loose with a screwdriver. be careful to panel can crack easy. good luck
Oct 11, 2007 at 9:18 AM
Suggested Repair
Replace the passenger window motor. The door panel can usually be popped loose carefully with a screwdriver; panels crack easily. The expert has not done this model, so the exact procedure and whether rivets come with the motor were not confirmed.
Conversation Summary
The owner of a 2001 Chevrolet Astro says the passenger window only travels the middle third and grinds when it stops, and asks whether the motor, regulator, or both are at fault and how to troubleshoot. The expert recommends replacing the window motor. Asked about difficulty, tools, and rivets, the expert says jobs vary by vehicle, has not done this model, and advises carefully prying the panel with a screwdriver because it can crack.
