2001 Chevy Astro Engine Start
150,030 MILES • 6 CYL • 2WD • AUTOMATIC
DELFLORES
When I turn the van for the first time in the day, the engine takes a long time to turn on. Usually a good 5 to 10 minutes of pushing the gas pedal and turning the ignition on. Once it I turn it on, it is good for the whole day, until the next day. then I have to start over again. What is the problem with it?
Apr 2, 2010 at 3:05 PM
LEGITIMATE007
  • 5,121 POSTS
well I suspect a dirty fuel filter or bad fuel pressure regulator, but in order to be sure, you will have to check the fuel pressure. also there is a good possibility that the throttle postition sensor is bad. so I will give you info on how to do a throttle body cleaning and how to check the fuel pressure.
Apr 4, 2010 at 5:36 AM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
