2001 Chevy Astro Cold Starting
WATERBOY
Engine problem
2001 Chevy Astro 6 cyl All Wheel Drive Automatic 165000 kilometers
During cold weather my vehicle will not start unless I have the block heater plugged in. These are the things that have been done to try and rectify the problem. First, I use gasoline antifreeze when filling up. Replaced the distributor cap and associated parts. Changed the battery to ensure strong cranking. Most recently changed the temperature sensor. When the vehicle is plugged in during the night it will start without hesitation. Is there anything else that may be causing this problem? Thank you.
Feb 8, 2008 at 4:43 AM
BLACKOP555
  • 10,386 POSTS
when you say you replaced the temperature sensor.
do you mean intake air temp sensor, or coolant temp sensor.
also are you sure you replaced the coolant temp sensor not the sending unit?
unhook the thing you replaced, and start the car if it shows full hot or all the way cold with a warm engine then you replaced the send unit not the sensor.
Feb 8, 2008 at 12:06 PM
TECHMAN1
  • 82 POSTS
I've had 4 Astro's. It is going to be your ignition wire between the ignition coil and the distributor. If this wire is gently leaning against an engine crossmember, look closely at that spot for microscopic "punch through" voltage holes. Do NOT buy cheap ignition parts for an Astro. Forget Duralast and other cheap makes. Buy the more expensive Sorensen and Autolight brand names. And only Autolight Double Platinum plugs.
I wrap my coil wire with 3/8ths inch spiral band and then cover that with half inch plastic split loom.
On my 4th Astro, I drive it 1,000 miles a week and have now 208,000 miles on it.
I have seen dozens of people with Astro problems that thought they had injector problems, sensor problems, computer problems, and just a good ignition system rebuild fixed them all.
Good Luck
Feb 8, 2008 at 4:16 PM
WATERBOY
I will check into that. I didn't complete the repair but I will inquire.
Thanks for the information. Very much appreciated.
[quote:7caf816b6b="blackop555"]when you say you replaced the temperature sensor.
unhook the thing you replaced, and start the car if it shows full hot or all the way cold with a warm engine then you replaced the send unit not the sensor.[/quote:7caf816b6b]
Feb 9, 2008 at 2:56 AM
WATERBOY
Definitely worth a try. That is one thing that hasn't been changed. Thank you for the information.
[quote:382693682a="techman1"]I've had 4 Astro's. It is going to be your ignition wire between the ignition coil and the distributor. If this wire is gently leaning against an engine crossmember, look closely at that spot for microscopic "punch through" voltage holes. Do NOT buy cheap ignition parts for an Astro. Forget Duralast and other cheap makes. Buy the more expensive Sorensen and Autolight brand names. And only Autolight Double Platinum plugs.
Good Luck[/quote:382693682a]
Feb 9, 2008 at 2:59 AM
