2000 Chevy Astro Vehicle hesitates during acceluration
2000 CHEVROLET ASTRO
153,500 MILES • 6 CYL • 2WD • AUTOMATIC
DARRYLD
History of repair: I took van in for a basic tune up about 2 months ago. Once I received the van back I notice a hesitation while accelerating, after about a week the engine service light turned on. I returned to the service repair shop for another diagnostic and repair. The van had a multiple miss-fire-fault in the ECM. The service center suggests that I replace the air flow sensor to correct the problem. I had them to make the repairs, and a month later the hesitation in acceleration returned.
Do you have any suggestion to my problem?
Jan 19, 2008 at 7:35 AM
MASTERTECHTIM
  • 4,750 POSTS
unplug the mass air flow sensor and see if you get more power. you could have a bad one. also check to make sure the air inlet snorkel is securely attached. if it is loose it will do the same thing. if i have helped you feedback and votes are greatly appreciated
Jan 19, 2008 at 7:56 AM
