2000 Chevy Astro Starting
109,582 MILES • 6 CYL • 2WD • AUTOMATIC
FANOF3ISME
I have a 2000 chevy astro van has gas new batt clean oil and air filter, but just last night we had a very hard rain followed hy lots of moisture in the air. Was wondering if that is why my van wont start or could it be something else that i could try to look at myself. Fuel pump is also working
Feb 5, 2008 at 6:46 AM
TECHMAN1
  • 82 POSTS
Your problem is distributor cap, and ignition wires. The classic symptom is that it won't start in wet weather. DO NOT buy cheap distributor cap, rotor, or ignition wires. Buy name brands like Sorensen, TRW, and Autolite. I failed to solve a problem with my Astro with Duralast distrubutor cap and Bosch Double Platinum plugs.
I will only use Autolite ignition wires and Autolite Double Platinum plugs.
Feb 8, 2008 at 5:53 PM
