2000 Chevy Astro spark plugs
WESTONSE2000
2000 Chevy Astro 6 cyl Four Wheel Drive Automatic
how to remove the spark plugs from the engine in a 2000 chevy astro van?
Oct 20, 2008 at 1:42 PM
SWILLIAMS
  • 597 POSTS
The easiest way is from the inside of the van. Pull the doghouse cover and use a 5/8" socket with attached swivel. It will make it easier. Then do them one at a time.
Oct 21, 2008 at 7:01 AM
TECHMAN1
  • 82 POSTS
[quote:f09ac2813c="westonse2000"]2000 Chevy Astro 6 cyl Four Wheel Drive Automatic
how to remove the spark plugs from the engine in a 2000 chevy astro van?[/quote:f09ac2813c]
I usually get the front 4 through the wheel well with a long extension, and the back 2 from underneath "by feel" since you can't see them. Astro's don't eat spark plugs. They eat ignition wires and distributor cap and rotors. I would use only Autolite Double Platinum plugs. I have had 4 Astro's and I have had the best results with this plug.
Ken
Oct 28, 2008 at 3:11 PM
