My 2000 Astro 'Service AWD' light comes on about 50% of the time for the last 6 months. When ever the ignition is turned on and you hear about 5 to 6 clicks below the dash the AWD light comes on. I had a few service technicians had a look at it; only one seems to be to figure the problem after scanning the vehicle and spending a few hours on checking the electrical system at no charge. He thinks the problem is the Transfer case shift control module located below the dash on the driver side kick panel. He is not a 100% sure.
Does anyone have such a problem, what's the solution?
Also can I change the module myself, I was told it has to be changed by a GM dealer because the system need to be reprogrammed?
What's the procedure to change the Module?
May 3, 2009 at 1:06 AM
