Hi there, from what I have read on Mitchell 1 you do require a scanner to do a code clear, have the problem rectified and the tech will then clear the code, codes will re set as soon as the ignition is on or engine started if the problem is not rectified first.
Mark (mhpautos)
SPONSORED LINKS
Sunday, December 6th, 2009 AT 6:20 PM
