2000 Chevy Astro Misfire on cyl #4
GPDADDYO1
  • 2000 CHEVROLET ASTRO
  • 6 CYL
  • 209,870 MILES
Change motor, dist, cap, rotor, wires, plugs, still misfires on cyl 4, checked harness with noid light, no power to #4 injector. The only code is a misfire on #4 cyl. Code 304
What are the possible causes, and could it be the pcm?
Tuesday, December 8th, 2009 AT 6:29 PM
Sounds like PCM injector driver on no.4
Tuesday, December 8th, 2009 AT 6:36 PM
GPDADDYO1
  • 6 POSTS
Do I need to replace the pcm?
Tuesday, December 8th, 2009 AT 11:11 PM
Check the light blue and black wire on no. 4 inj. Harness for open or short if okay replace the PCM
Wednesday, December 9th, 2009 AT 2:10 AM
GPDADDYO1
  • 6 POSTS
Thanks for the answer, I'll let you know what I find out.
Wednesday, December 9th, 2009 AT 7:14 AM
GPDADDYO1
  • 6 POSTS
Thanks for the help, it ended up being a broken wire.
Luck for me it was close to the pcm.
Monday, January 25th, 2010 AT 8:17 AM
