2000 Chevy Astro MASTER CYLINDER
121,236 MILES • 6 CYL • 2WD • AUTOMATIC
TUFFYXEN
NEW MASTER CYLINDER BLED PROPERLY ON BENCH AND THRU LINES ON VAN, GREAT PEDAL GOING IN DRIVE, BUT WILL DROP IN REVERSE ON JUST A SMALL TURN OF THE WHEEL. PLEASE HELP MY WIFE TO KILL ME
Nov 24, 2009 at 5:43 AM
MERLIN2021
  • 17,250 POSTS
Check adjustment of rear brakes. Then go for a ride on gassy oe gravel area, step hard on pedal to activate the abs pump, do this several times, it can help remove air in the abs, which may have been trapped by bleeding an air buble into it!
Nov 24, 2009 at 6:33 AM
